Can't Parametrize Joints?
Willem.smithUWEUR
Willem.smithUWEUR
I'm trying to add an open and close state to this box. I Have a linked spreadsheet where I was planning to simply type 90, 0, or -90 for the three box states. However, when I try to enter the parameter into the joint, it doesn't seem to care. Are joints simply not able to be used with parameters?
The spreadsheet is properly linked etc.
wgraham
Likely a matching units issue.  Try "Box_State * 1 deg" to convert the unitless value from Excel to an angle.
TheCADWhisperer
Did you specify deg as the units in the spreadsheet?
If not, Inventor assumes mm (or in).
Willem.smithUWEUR
Ok, will try, thanks!
