Inventor Forum
Can't offset sketch from projected geometry onto work plane.
2 REPLIES 2
b2744442
98 Views, 2 Replies
I want to make my sketch 0.005 inch smaller. When I try to use the Offset tool in my sketch for the work plane, I get a stop sign cursor, no preview and no ability to change anything. It looks like I can change the length of a component in the sketch in this screenshot but when I type something in it changes back to what it was before.
I got the sketch by choosing Project Geometry on a 90 degree plane. Is it possible to offset the sketch?
2 REPLIES 2
hosford
in reply to: b2744442
Most likely due to a radius that would not be able to be reduced.
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
johnsonshiue
Hi! The 2D Sketch Offset isn't good at handling degenerated geometry. I suggest you extrude the profile as a surface and use Thicken/Offset command to offset the surface inward. Then profile the edges to the sketch.
Many thanks!
Software Test Engineer
Technology Administrators
