Can't get sweep to work on 3D skecthes using path and rail or path and surface.
Can't get sweep to work on 3D skecthes using path and rail or path and surface. See attached file.
mdavis22569
I can get it to work on the yellow ...but now the green ...
Mike Davis
johnsonshiue
Hi Brian,
There are a few places I would do differently. Please take a look at attached part. First, sketch3 is not constrained properly. The spline should be at least tangent continuous all around.. Second, this is a symmetric part. You don't need to model the whole thing. Just create one side and then mirror the other half. Lastly, sweeping as a solid may limit your choice in terms of intersection. I used surface sweep to create outer surface. Then use sculpt command to turn it back to a solid. Let me know if you have any question.
Many thanks!
Software Test Engineer
What method did you use?
