I'm trying to extrude a sketch (containing a sketch block), but when I do this, I can't select the profile. I can select the inner or the outer lines and extrude them as surfaces, but that's not what I want. I tried running the sketch doctor, and the only problem I found was a redundand point (the insertion point of the sketch block). I can't imagine this would be the problem, but I even tried to delete that point but I still couldn't extrude the profile.
What could be the problem and how could I fix this?
File is in the attachment.
