Can't extrude sketch
mat_hijs
mat_hijs
I'm trying to extrude a sketch (containing a sketch block), but when I do this, I can't select the profile. I can select the inner or the outer lines and extrude them as surfaces, but that's not what I want. I tried running the sketch doctor, and the only problem I found was a redundand point (the insertion point of the sketch block). I can't imagine this would be the problem, but I even tried to delete that point but I still couldn't extrude the profile.
What could be the problem and how could I fix this?
File is in the attachment.
mcgyvr
The block has issues... Explode the sketch...Edit the sketch.. Right click on any line.. Select "Close Loop" and follow along.. Note the areas it addresses..
JDMather
Did this come from a dwg file?
If yes, can you Attach the original file here?
mat_hijs
It did indeed come from a dwg, I edited the dwg in autocad to make it a closed loop, make everything right before copying it to inventor. I didn't see any errors about an open loop in the sketch doctor. Now I tried to do as suggested in this thread, and this worked. What's weird though, the point where the loop wasn't closed was created in autocad using the fillet command, so I don't really understand how there can be an opening. Any idea how this can happen though?
