Hi, Can you replicate the problem and show us an image?
Have you checked that when the problem appears is not your assembly in "express mode"?
When the express mode is activated, many options are inactive. This mode is activated when you have an assembly of many parts.
In this case you just have to click on "load full" to load the assembly completely as detailed in the image.
You can configure the express mode you must go to options of the application, in the assembly tab, and in the lower part configure the quantity of unique parts from which the express mode will be loaded. By default they are loaded from the 500 parts.
I hope this helps solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
