can´t change the path in libraries.
peter.sondergaard
Observer Observer
peter.sondergaard
Observer
Observer
HI
After i have install ondrive on my labtop the path dosen`t fit anymore.
I have change the path for projekt but the libraries cant i change
i have try to change the path in the Projekt folder but i can`t cause i get the alarm, but nothing is openUdklip2.PNG
johnsonshiue
Hi! Is the ipj file itsef editable? Make sure it is in a location that you can write to. I don't understand why editing a project file is blocked. I cannot explain it. But, another thing to try is to edit the ipj in a Notepad. It is a text-based xml file, sort of readable. You can replace the project path easily.
Many thanks!
Software Test Engineer
peter.sondergaard
Observer
Observer
Hi Johnson.
Thanks for your help.
This help me alot.
But it will take a lot of time.
