Can't apply values in any direction when using edit form. How do I fix this so I can edit a freeform using direction values?
stefan.liedman
Message 1 of 8
stefan.liedman
I am trying to use edit form on a freeform shape. When I double click on the centerline I want to edit the form and make it wider in the middle. However, I can only click and drag it but not input a specific value such as 15 mm. In the tutorial that I am watching, the directional inputs are visible next to locate. How do I fix this so I can also add specific value inputs?
Replies (7)
Message 2 of 8
CCarreiras
HI!
I guess you are selecting the symmetry plane instead of the geometry.
Try to select a node in the geometry and drag it.
CCarreiras
Message 3 of 8
stefan.liedman
Hi!
It does not matter what kind of transformation I try to make or if I select the plane or node. I still do not get the option of adding a specific input on how much I want to transform it in i.e. the Z-direction.
Message 4 of 8
CCarreiras
Upload the part here and we will take a look...
CCarreiras
Message 5 of 8
stefan.liedman
I have uploaded the part. It is probably an application setting or something that can activate it, but I can't find it.
Message 6 of 8
CCarreiras
I mean... post the part here... and we take a look....
CCarreiras
Message 7 of 8
johnsonshiue
Hi! I believe it was a known bug in 2023 RTM version. Please install 2023.1 update. The issue should go away.
Many thanks!
Software Test Engineer
Message 8 of 8
stefan.liedman
Hi!
That actually worked! It did not cross my mind that it required an update, thank you very much!
