Inventor Forum
Can someone make this a solid?
5 REPLIES 5
274 Views, 5 Replies
I'll admit it. I ignored all those excellent tutorials by JDMather and haven't had the discipline to learn dealing with surfaces like I should.
Much to my chagrine, the attached STEP file comes in as a collection of surfaces.
Feed a man a fish: Can someone please turn this into a solid? Any version will do - I'm using 2010.
Teach a man to fish: Alternatively (or in addition), what's the process one must undergo to turn this file into a solid?
See attached step file.
5 REPLIES 5
Looks like step file attachments are verboten. Here it is as a zip.
mflayler
After you have it imported you can simply use the STITCH command and it should work out for you. Make sure you examine your Options button before hitting the Open button for more options when you import.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
john.hahn-francini
I opened the step file using the default options which resulted in a single composite. I then clicked Stitch and picked the composite. It stitched nicely to a solid. I have attached the result. You will need to move the End of Part below Stitch Surface1
Well schitfire that works a treat. Thanks guys.
JDMather
>Teach a man to fish
In case you get one that is a bit more difficult
http://www.myvbooks.com/ac55jsp/stores/1/ML205-1P_Working_with_Neutral_P309C98.jsp
