HI
Why can’t i do anything with this part, only viewing
It is converted from another program
Regards
Henrik
Solved by Henrik_Lo. Go to Solution.
Solved by KevinLi-Autodesk. Go to Solution.
Hi hlo,
This is a mesh data which only can be viewed in Inventor.
I convert it to solid for downstream work. The version is Inventor 2016 RTM Update2.
Hi hlo,
There is a tool named "Mesh Enabler" which is an Inventor addin, after install it, then can convert mesh to solid or composite. Detail information please go through this page: https://apps.exchange.autodesk.com/INVNTOR/en/Detail/Index?id=appstore.exchange.autodesk.com:meshena... , it is exclusive to subscription customers :).
HI
Thangs for replying, again, iam a subscription customer and will try this program
Regards
Henrik
