I am getting this error message while I try to save my assembly.
If I open individual sub-assemblies and try to save hem they do not give me any error.
Any insight into this would be really helpful.
Thank you
Can you use the Windows command Win e to go to Windows Explorer and follow that exact path and post screen capture image of the path... ...similar to this example screen capture but with your indicated path to 1473-ASSEMBLY.iam...
known issue where every now and then either Inventor or Vault lose the ability to detect a file that is present. This issue does not appear to be tied to a specific version and last I knew there is no fix.
Ref one of many posts already on this topic;
Hi! I believe you want to make sure get the non-checked-out files from the Vault server. Then in Inventor, go to File -> Manage -> Refresh. You should be able to save. The error message indicates that some files you have loaded in Inventor have been changed in a different process. Inventor cannot find them.
Another possibility (less likely) is that certain dlls were not loaded when you attempted to save. Close Inventor and go to Control Panel -> System -> Advanced System Settings -> Environment Variable -> create "DYNAMIC_LOAD_APPLETS" and set the value to 0. This will ensure all Inventor dlls are loaded on startup as opposed to loading on demand based on the open file types.
Many thanks!
