Inventor Forum
Can not index a FARO scanned file (.fls) to create point cloud
4 REPLIES 4
1578 Views, 4 Replies
I have a scanned file from a FARO scanner.  The file type is ".fls".  When I try to index it in Inventor 2013 to convert it into a .pcg point cloud file, I get the error as shown on the attached screen shot.  Also attached are my system properties.
I was able to index the same .fls file using AutoCAD 2013, however, I want to do it in Inventor. Can anyone help?
Nick
4 REPLIES 4
kubitTilo
Hi Nick,
I'm not familiar with Inventor but you can try to search Inventor's installation directory for the FARO DLL files and overwrite them with the new versions (similar like the AutoCAD/Navisworks/Revit solution http://tinyurl.com/d2bcmh4).
Tilo.
Tilo Pfliegner
in reply to: kubitTilo
Your proposed solution [http://tinyurl.com/d2bcmh4] worked for my AutoCAD 2013.  But for Inventor 2013, I do not know what folder to copy the FARO .dll file into.  The solution hyperlink only specifies the .dll file location for AutoCAD ( C:\Program Files\Autodesk\AutoCAD 2013\IndexCodecs) and not for Inventor.  Inventor 2013 does not have a folder called IndexCodecs.
What folder in the Inventor installation directory do I need to put the FARO .dll files into?
Nick
kubitTilo
I don't know, but if you search Inventor's installation folder (including all subfolders) after iQOpen.dll for example, you should be able to find out the correct folder.
Tilo Pfliegner
Got it.  The correct location in Inventor 2013 is:  C:\Program Files\Autodesk\Inventor 2013\Bin  After copying the .dll files into this folder Inventor was able to index the .fls file.
Thank you for your help!
