Cam Follower With Spring Gear Assembly
Message 1 of 11
forum
I have to do an assembly but I do not know how to.
This is how it should look like.
What I have is not fully constrained and the spring I got it from grabcad.
I do not know how to design the spring I require
Dimensions are. Spring Dia. 13mm, length 39mm, wire dia. 2mm.
It is a center hook.
How do I get the spring to change length when it is stretched and how do I assemble them together like the picture above.
TIA
Haziq
kelly.young has edited your subject line for clarity: assembly
Replies (10)
Message 2 of 11
Xun.Zhang
Hi Haziq,
Have you try the Extension command in assembly?
You can refer more from below help link.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?contextId=DA_EXTSPRINGSCOMP1_DIALOG
Xun
Message 3 of 11
CCarreiras
Hi!
Tip:
You can create some work planes axis and points in the spring to help you place the spring with other parts in the assembly.
CCarreiras
Message 4 of 11
JDMather
Thanks for the Flower, but do you know how to use Pack and Go?
Message 5 of 11
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous there are a few ways to go about drawing the spring, but what is the desired intent of the model?
The Extension Spring in the Design Accelerator will be more for getting exact results. The forces and stress calculations might be a bit much for what I'm guessing you're trying to do.
Does the spring need to be extending while the gear goes just for looks or are you going to try to do analysis with it?
If you want just a visual spring I would go about drawing it a bit differently and using the spring length as the driving factor.
More like drawn here: compression of springs
I messed around a bit, like previously stated if you have a parameter map you could create an individual part just for location and lock in your parts in the assembly much easier.
I would focus on measuring and drawing all of your parts.
Once you have them all you can insert them into an assembly and constrain.
After that you would go in and set up your custom spring that would be adaptive to the rest of the assembly.
If you can get that far it would be easier to show you how to add the spring instead of missing parts and not knowing exactly how it goes together. (the ppt was good to have but a bit misleading).
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 6 of 11
Hahah,
I do not know what it's called. So I just gave it a name flower as it looks like a flower.
Pack and Go? Thanks for telling me. Now I know.
Message 7 of 11
Just played around with it.
I guess its my assembly skills that is lacking.
Thanks for pointing the tool out.
Message 8 of 11
I will give it a shot.
Message 9 of 11
Hello Kelly,
Thanks for helping me in this thread.
How did you do that in assembly?
I do not know how to set constrains and joins etc.
It would be a great help if you could guide me though the process.
I would like my assembly to be exactly like yours.
Message 10 of 11
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous it all depends on how you start the design process.
If you have existing pieces and you draw them individually and bring them together in an assembly they might not fit together properly. This was the issue with the gear teeth moving using contact set so I had to fudge to a visual rotational constraint assumption, not best practice.
If you take the time to create a base sketch showing all the parts and link all the parts to it, you can ensure proper fitment.
I would take the picture you have supplied in the ppt and make this base sketch. This will include the profile of each gear, hole locations that you have specified, and determine clearance, rotational interference, and spring travel length.
There are a few modeling techniques you could go about to create the assembly:
 Attached are the assembly and two new files, spring and base path.
Message 11 of 11
Kelly
I do not know how to resolve the problem of mate flush constrain between the mid plane of camfollower and whole part of flower.
I have put the errors I face in the error folder.
TIA
Haziq
