Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Cam constraint issue
wanumej4
Observer Observer
wanumej4
Observer
Observer
Anyone know how i can stop the rocker from teleporting location on the cam. I want it to follow the cam whilst it is on the top but it always telports to the side.
kacper.suchomski
hi
The key is to position the component before creating the constraint.
It can also be helpful to add an angular constraint that defines the possible range of positioning relative to another element (or workplane).
Kacper Suchomski
johnsonshiue
Hi! Please share the Inventor files here or with me directly at [email protected]. I would like to understand the constraining behavior better.
Many thanks!
Software Test Engineer
wanumej4
Observer
Observer
Hi, i have sent the files onto your email, please let me know.
johnsonshiue
Hi John,
Many thanks for sharing the files! Without disclosing the detail here, I can comment on the issue as the following.
I took a quick look at the assembly. I think I know where the problem is. Though the behavior looks wrong in terms of the assembly design intent, it is actually a legitimate solution from Assembly Constraint Solver’s perspective. The rocker subassembly has way too many degrees of freedom. A limit angular constraint can help restrict the movement. Just open the rocker subassembly, add the angular constraint between the rocker arm and the bolt, and set a reasonable limit range. It should work better.
Thanks again!
