Calling out CoolOrange Threads in a Drawing
carsonp01
carsonp01
So I finally downloaded and installed CoolOrange's thread modeler today, and it's great. The only problem I have with it at the moment, is that when you insert the part with the modeled threads into a drawing, the "Hole and Thread" annotation feature cannot call the threads out. Does anyone know how to use the "Hole and Thread" feature on a modeled thread. Thank you in advance
-Carson
johnsonshiue
Hi! Inventor Drawing Hole/Thread note is based on the cosmetic thread created in Inventor. Physical thread is not included unfortunately. If you want to document physical thread, I suggest you try Fusion 360.
Many thanks!
Software Test Engineer
SBix26
It is possible to add the cosmetic thread feature to the cylindrical face that remains after the coil cut.  It may be difficult to select it in a drawing, though.
Sam B
Inventor Pro 2022.1 | Windows 10 Home 20H2
LinkedIn
