calculating weight in inventor
This widget could not be displayed.
how do i calculate weight of a part in inventor.
Replies (25)
iProperties >> Physical tab.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
Also make sure you have applied the correct "material" to your part and
aren't used the "Default" material.
Dell M90 - FX2500m 1920x1200 32bit
Win XP-Pro sp3
4gb mem
Nvidia: Driver: 156.83 Bios: 5.71.22.16.16
IV20010-Pro Suite SP1
AVG 8.5
SpaceTraveler 3.7.18
AVG 8.5
"Dennis Jeffrey" wrote in message
news:6260383@discussion.autodesk.com...
How do you find the weight of a whole assembly?
ferrisb
See attached.
kelly.young has embedded your image for clarity.
Same way. Apply materials to all parts individually, then iProperties in
the assembly.
Hello, is there a way to change units of calculated weight from kilo grams to grams? I have elements with weight smaller than 1 gram and in i properties it shows 0,000 kg
mrattray
Try changing the uniots in the document settings. If you want mass to always be in grams you'll have to update your template with this change.
Mike (not Matt) Rattray
Thank you, got it
hi is it possible to get the Kg into Te (tons)
mcgyvr
No. Thats not an option.. You will have to manually convert it.
Prav!n
Hi
Is it possible to get Raw weight of a part in inventor.
As observed, the inventor reflects with the finished weight alone.
Eg.: I do need a weight of Base plate.
       The base plate would be procured for 1000x1000x28 and machined to 25mm thk.
       Some holes of 30mm dia would be drilled on the plate.
       The inventor provides the mass of the plate as Fiished weight (subtracting all machined and drilled surfaces)
       i need the Raw weight of material (for 1000x1000x28).
How do i get both weights in inventor?
jyager
Check the weight of the part before you modify it, or just do the math. (a 24X24 plate at 25lbsper square foot=100lbs)
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
JDMather
...if the math is too complex, there are several other ways...
1. As suggested - roll the EOP up before the cuts are made and check.
2. Do the machined part as a Derived Component - now you have in both states.
3. Do the machined features as multi-body solids, check and then Combine-Subtract.
Prav!n
Hi
Thank you for your replies.
My requirement is after completing an assembly and extracting Bill of Material (Part Lists), the raw weight has to be reflected in individual Part List.
The Mass in Part List shows the Finished weight of component.
Is there any possibilities to see both raw weight and finished  weight in Part List.
Eg.:
ITEM              DESCRIPTION               QTY    RAW WEIGHT    FINISHED WEIGHT
 01       PLATE 100 x 100 x 25 mm       1        1.963 kg               1.577 kg
Any feedbacks is Greatly Appreciated !
Thanks.
rwollenhaupt
With the way we have our templates setup, it would be simple to assign the raw material mass to a parameter. Using your plate as an example, we would start by using our plate template that I have attached. We would start by setting parameter G_T to 28 mm, G_W to 100 mm and G_L to 100 mm. Now you have the raw size information and can setup a user parameter to calculate the raw material mass (RAW_MASS). The RAW_MASS parameter is exported to iProperties so it can be used in the Parts List. We have a template for all steel shapes which we use as our starting point for model creation. All our templates are setup similar to the plate template which would make it easy to come up with the raw material mass. Hope this helps.
Rodica.Mangau
Weight or mass? The weight (Force) must be = mass x acceleration
W = mg
There's not a tab that just says weight you need to be more specific
SBix26
@Anonymous
Who needs to be more specific?  This topic goes back quite a few years and versions, and some of the users' accounts are inactive.
Sam B
Inventor Pro 2019.0.0 | Windows 7 SP1
LinkedIn
gbradley
How do I get to Document settings so that I can change the Weight to Grams?
Do I do this on the Model or in the Drawing?
Inventor 2019
