Inventor Forum
Calculating total volume in Inventor?
9 REPLIES 9
Message 1 of 10
30366 Views, 9 Replies
I want to know if it is possible to calculate the water displacement volume of an assembly if it were immersed in water.
In other words,  I want to create a file in which ALL hollow spaces inside structural members, valves, pipework etc are assumed to be solid so that when that assembly is dropped in water, the total volume of water being displaced will be equal to the iProperty value for volume.  I know its possible to hole patch when creating a shrinkwrap,  but this is only effective for 'circuler' hollow spaces and does not fill obscure or rectangular shaped empty volumes.
Regards and thanks in advance,
Josh
9 REPLIES 9
Message 2 of 10
PaulMunford
Check out this post from mark Flayler:
http://blogs.rand.com/manufacturing/2010/01/determine-volume-of-a-container-using-autodesk-inventor....
Autodesk Marketing Manager D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 10
bobvdd
in reply to: PaulMunford
Another solution when you are working with 2013 is to use the "Fluid volume" function that is available in Fusion 2013.
Bob
Bob Van der Donck
Principal UX designer DMG group
Message 4 of 10
PaulMunford
in reply to: bobvdd
Ooo! an Easter Egg!
Cheers Bob 😉
Message 5 of 10
mflayler
That Fluid Volume tool is a godsend for CFD use.  I originally thought it only integrated for CFD and Simulation, very happy to see it in normal Fusion.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 6 of 10
PaulMunford
in reply to: mflayler
I can't wait to see you post on it Mark 😉
Message 7 of 10
Hi Paul,
Ive seen that video before actually!  It's very useful for single components but for something fairly complicated (see attached image) it doesnt work.  I can do hole patching in a shrinkwrap on the attached assembly but obviously this only applies when you have 'circular' holes...
Message 8 of 10
mflayler
When I look at that model, the word rough estimate comes to mind.
take the volume of the model right now, and then make a seperate part representative of the outside extents.  Then do some simple math to get close.
Message 9 of 10
I have considered making calculating accurate volumes my mission to accomplish with Inventor even if it kills me.  Our product is a filled shell, with many internal components of different materials and our CG is very important.  I have found a way with simpler assemblies to fill gaps, etc (using the weldment), but some assemblies are nearly impossible or not yet possible to weld.
However, in your case, are all the parts solid (closed end) already?  It looks like you could draw a simple rectangle outside the assembly and create a derived part, subtracting your assembly from the "block" you created around it.  You can take the diffence in volume of the "block" and what is left after you subtract your assembly to form the new block and that should be your displacement.  Hopefully...?  What you would have to do I suppose is isolate the one big remaining block because you would have all kinds of trash remaining inside the tubes and hollow parts, etc.
You may want to do a test with that and see if it results in a multi-body situation (best case) or a single body solution (not much help at all).  Even with a single body you could try and select the interior (Delete Face) lumps, but very time-consuming still.
That might be why the new derive as a solid feature in 2013 came about, but I have only read about it so far and could completely misunderstand its function.
Message 10 of 10
Go to the iproperties dialog box.  Open the "Physical" tab.  Click on "Update" and the General Properties will be filled out, volume included.  If you have the correct material, density, and mass can also be trusted as being correct.
Technology Administrators
