Inventor Forum
calculating stress analysis
4 REPLIES 4
367 Views, 4 Replies
Can anyone do stress analysis on the attached part? I want to know the maximum load it can withstand.
TQ
4 REPLIES 4
jingyi.liu
You should depict your constraint, load and material for stress analysis, otherwise I could tell you the result.
Jingyi Liu
Inventor Product Manager
fixed at the bottom lifting lug...( note that radius curve is top side)...material is mild steel RSt 37-2
jingyi.liu
Attached please find the simulation result for your reference,  I don't know correct physical property of  Rst 37-2, just use Mild Steel in the material   library to replace it.
You can try the Autodesk Simulus Technology Preview, it's a free simulation products you can download it from Autodesk lab, you can use it before Jan 31,2013.
http://labs.autodesk.com/utilities/kraken
Jingyi Liu
in reply to: jingyi.liu
Hi mates,
I have got a problem like this one.Actually, I do everything up to the report. But I can't find out the force in the report which equipment can withstand. Taking this example, I'd wonder if anyone help me.
Thanks in advance.
