I am trying to create a cable route as shown in the picture and model (attached).
Having trouble configuring the route correctly.
The first steps to create the harness will be to create the connectors at each end. On each connector, the connector points need to be added. This is what the wires connect to.
Add the wires to each connection point on the connectors.
Add the sleeve along the route path.
I tried that step, but couldnt route it correctly, would you be able to show the steps with the model and share it.
I will use that as reference to try it out.Thanks!
Here is the mocked up with a simple cable. I also threw in a connector so you can see a sample of how a connector is set up.
