Cable & Harness Ribbon Bend Radius
Message 1 of 32
Whenever I create ribbon cables, it always takes so long because I have a hard time getting the cable to represent in the rendered mode because it is saying the bend radius is too tight. Is there a way to turn off the "bend radius" requirement. I am not too concerned with the bend radius as it is only for visualization purposes.
kelly.young has edited your subject line for clarity: Ribbon Cables
Replies (31)
Message 2 of 32
Cadmanto
Kevin,
How are you creating the ribbon cables?  Tube and pipe, sweep, or some other method?  Can you post some images please?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 32
I am using the Cable and Harness section
Kevin Pinks
Mechanical Draftsperson / Doc Control
Engineering
Industry Business
Schneider Electric
D +1-613-591-1943 x79387
F +1-613-591-1022
E [email protected]
415 Legget Drive, Suite 101
Kanata, Ontario K2K 3R1
Canada
[http://www.apcmedia.com/emailsignature/images/998-19615502_BrandBusinessBanners_620x80_5.jpg]<>
*Please consider the environment before printing this e-mail
[Blog]<> [FB] <> [Twitter] <> [Linked-In] <> [Youtube] <> [Instagram] <> [Google] <>
Message 4 of 32
mcgyvr
Never used ribbon cables but use wires all the time but...
Did you try to Edit the harness settings and uncheck "Active Bend Radius Checking" on the general tab..
Ribbon cables don't seem to have a bend radius multiplier like regular wires do so I'm not sure where its even pulling a bend radius multiplier from...
Good luck.. I know that can be a total PITA... I run into the "The sweep operation failed for the harness..." ALL the time when attempting wire routing..
Message 5 of 32
mercerc
I did a quick review of the ribbon cable and I would like to see an example or a screencast capture of the issue so I can get a better handle on it. It sounds like it's pulling from the bend radius for the cable and harness end.
Charlie M
Inventor Product Support Specialist
Message 6 of 32
mcgyvr
Are you not able to create a ribbon cable and give it a sharp bend,etc.. to reproduce Kevins issue?
I can easily get "The sweep operation failed" error but nothing about a bend radius error with a ribbon.
@Anonymous Kevin... Please post a screen capture or sample dataset that shows the issue so we can help.
Message 7 of 32
Here is the cable
Kevin Pinks
Engineering
Industry Business
Schneider Electric
F +1-613-591-1022
E [email protected]
Canada
Message 8 of 32
mcgyvr
@Anonymous wrote:
Here is the cable
@Anonymous Nothing was attached..
Message 9 of 32
Kevin Pinks
Engineering
Industry Business
Schneider Electric
F +1-613-591-1022
E [email protected]
Canada
Message 10 of 32
mcgyvr
@Anonymous Still nothing..
How are you accessing these forums? Up to date internet browser?
Seems like you are using some email/news reader or something based on all that crap in your sig file that comes up when you post..
Message 11 of 32
There does not seem to be an option for specifying the bend radius in a ribbon cable?
kelly.young has edited your subject line for clarity: Bend Radius
Message 12 of 32
Could someone please take a look at this attempt on a ribbon cable and tell me where I am going wrong. The bend radii do not seem too small.
Message 13 of 32
mcgyvr
There is no harness in those files..
Message 14 of 32
mcgyvr
Is that a statement or a question?
You can specify the minimum bend radius in your harness library for each wire type..
But it really doesn't do much nor force compliance with that.. until you do this..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Message 15 of 32
I do not see this for ribbon cables, but yes I do for wires
Message 16 of 32
Message 17 of 32
mcgyvr
yeah sorry.. ribbon cables do not include a min bend radius specification and are not part of the bend radius test functionality either..
Thats only for wires and "regular" cables not ribbon cables..
Message 18 of 32
Here is my assembly with the ribbon cable
Message 19 of 32
mcgyvr
@Anonymous Try again.. Nothing attached at all this time..
Message 20 of 32
Here is the cable assembly that I am having troubles with
