C of G Issues
C of G Issues
jason_charnley19
C of G Issues
jason_charnley19
I am modelling a sphere with cutouts that I require to be perfectly balanced.  When I begin the basic sphere is fine - Center of gravity zero and Inertial properties for Ixy, Ixz & Iyz correct - all zero.
Then I add to cutouts and all is fine -
Then I put a bore through and still good.
Then I add a radius to the corners of the cutouts and the Center of gravity and Ixy, Ixz & Iyz are incorrect - they should still be zero.
This also happens if I add other features to the model such as cutouts in the bore -
As all these features are symetrical I would expect the center of gravity Ixy, Ixz & Iyz to stay at zero.
Can you explain why I am getting an error?
swalton
You may get better answers on the main Inventor forum.  I've asked the mods to move this post.
Do you have a sample part file you can add?  It may help others troubleshot the issue.
Steve Walton
Inventor 2025
Vault Professional 2025
jason_charnley19
Hi Please find attached test file
catBUN5M
There is no attachment?
But from looking at the pictures I would think that this is an Inventor rounding issue during calculation of COG or something. Anyway, the deviation is so small 0,000007mm that in practice it is 0.
