Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Bug when opening multiple files
mat_hijs
mat_hijs
I think I may have found a bug. When opening multiple files from the open dialog the file open options are not used on all of them, just on the first one.
I have a bunch assemblies where I used the "default" view representation to configure the visibility of components, in these assemblies I only use the "default" view representation, it is always placed with the "default" view representation and it is always saved with the "default" view representation.
In my open options I selected the "Last active" option for Design View. However, when opening multiple files only one file is opened with the "default" view representation active, the rest of the files have the "Master" view representation active.
When opening these same files from the explorer they all open with the "default" view representation active so I'm pretty sure I didn't just accidently save it with the wrong view representation active.
johnsonshiue
Hi Mathijs,
This is an interesting observation. I was not aware of the behavior. I tried a simple test, by setting Open Part to Design View Master. I cannot seem to reproduce it. Could you share an example that exhibits the behavior here?
Many thanks!
Software Test Engineer
mat_hijs
I can't seem to reproduce it anymore today either. However, yesterday I did do the same thing multiple times and kept getting the same behavior. I'll keep an eye out if it ever occurs again and if it does I'll post the example here.
