For a hobby project, I need to design a laser cut acrylic case. This case should also feature laser cut engravings like text and a logo.
As the Laser Cutter only has a very limited interface, I need to create a PDF with colored lines (red = cut, black = engrave) with scale 1:1. This on its own is achievable with the Drawing editor in Inventor 2017.
The problem is that embossed text and DWG/DXF logos on Parts do not get exported to PDF properly: The curves are not exported as true curves but as line segments with low resolution for text/paths that are about below 5mm in letter size. Paths get offset by rounding errors (even the non-emboss paths). The path widths (defined by the Layer Style) have no impact on the resulting path widths in the PDF. They always keep the same, which is not working out for manufacturing. The colors work though.
And this does not depend on Vector DPI settings, nor does it on exporting to other formats such as DWG or DXF, exporting the surface in the Part Editor (to DXF) or printing with a PDF printer driver. All the exports loose in quality and larger scaling is not an option.
Luckily I found a workaround:
I hope Autodesk is willing to fix this bug, as it is hindering people from designing small scale parts.
Best Regards
Markus
The Inventor part to be laser cut (45mm x 45mm x 2mm):
The text emboss features high resolution:
The Inventor Drawing with red and black lines for the export to the laser cutter:
Also high resolution here:
The export dialog (4800 DPI):
Bad resolution in the PDF:
As a workaround open the .dwg in Autodesk DWG TrueView:
Export a PDF with a high precision:
And the resulting PDF with high precision:
Hi Markus,
Looks a requirement to enhance the quality of pdf, I have reported it to the development team, track ID 137708. Thanks for your detailed report.
@Anonymous
Markus,
There may be some things you can do now to overcome the limitations of your laser cutter..
Have you tried to export the face from the flat pattern?
In the ipt file create a flat pattern of your part and then right click on the flat pattern node in the model browser and select "save copy as" and you can save it as a dwg or dxf.. Once you hit save a dialog box comes up that allows you to map certain layers to colors and also control how curves are changed to line segements,etc..
Note: you will need to do your nesting in Autocad and export to your laser from there..
