Bug in the Parameters window if the Dynamic Simulation Environment parameters are present
Hello all.
A bug was encountered while working in the Parameters window if the Dynamic Simulation Environment parameters are present.
When you try to change such a parameter, the new value is not displayed, although it is remembered.
The changed value is displayed after closing and reopening the parameter window.
Inventor 2021.4 (but it was the same before, for example, in 2021.3)
PS. In version 2020 all works OK.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
