Bug in the Parameters window if the Dynamic Simulation Environment parameters are present
Alexander_Chernikov
Mentor Mentor
Alexander_Chernikov
Hello all.
A bug was encountered while working in the Parameters window if the Dynamic Simulation Environment parameters are present.
When you try to change such a parameter, the new value is not displayed, although it is remembered.
The changed value is displayed after closing and reopening the parameter window.
Inventor 2021.4 (but it was the same before, for example, in 2021.3)
PS. In version 2020 all works OK.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
jan_priban
Hello Alexander,
Thank you for reporting this issue, you are right. Parameters dialog in Dynamic Simulation does not show updated value. This issue is reproducible in R 2021, R 2022. But it has been fixed in our internal builds targeting the future release. Unfortunately, we can't backport this fix to older versions.
Regards
Jan Priban
