Inventor Forum
Bridge Model Inventor Arch Problem!
9 REPLIES 9
Message 1 of 10
647 Views, 9 Replies
Hi all,
I have to create a bridge model for my final year project.
Currently, I am modelling half of the bridge as it is a symmetrical bridge. So far I have been able to add the spans, piers and parts of the arches.
However I am having a problem making the arches look more 'realistic'
This is how I need it to look:
https://imgur.com/t702STA
This is what I am working with currently on Inventor 2018
https://imgur.com/J9qmaKC
https://imgur.com/27PLJqh
https://imgur.com/BGifK3v
I cant seem to get the top of the arches to extrude in a way that it fills up to the deck/piers so it actually looks like the bridge
Any help would be appreciated!
Hi all,
9 REPLIES 9
Message 2 of 10
mcgyvr
mcgyvr
@Anonymous Please post your ipt file..
Images are helpful but not nearly as much as having your actual Inventor files to examine..
But in general if you want it to extend up all the way then your sketch should have been that profile instead of the narrow strip..
Post your file and we can easily modify the sketch if you can't figure it out..
Message 3 of 10
in reply to: mcgyvr
 @mcgyvr Hi, many thanks for your reply
See attached for the ipt file for more details
Would be great if you could resolve this issue as I am very new to this software and do not have much time to master it.
Message 4 of 10
mcgyvr
mcgyvr
See attached..
Is that closer to what you are after..
See attached..
Message 5 of 10
in reply to: mcgyvr
@mcgyvr Hi,
Yes that what I was after - Is it possible to complete the rest of them?
@mcgyvr Hi,
Message 6 of 10
TheCADWhisperer
TheCADWhisperer
Yes, it is possible to create the rest of them using @mcgyvr example.
(Where is your instructor?)
Message 7 of 10
mcgyvr
mcgyvr
@Anonymous wrote:
@mcgyvr Hi,
Sure.. Go right ahead..
Right click on extrusion 7 and edit the sketch and see what I did and then you should understand it..
Its all about sketching the profile that you want.. If you wanted a wide/fully closed arch why did you draw a thin/open one..
@Anonymous wrote:
@mcgyvr Hi,
Message 8 of 10
in reply to: TheCADWhisperer
@TheCADWhisperer  Supervisor assigned to this project is not really providing any guidance regarding software -  Have to learn software on our own unfortunately
Project is about bridge analysis and me and some other students have had to basically learn a bunch of different software on our own
Message 9 of 10
in reply to: mcgyvr
@mcgyvr Many thanks for your help - I will attempt it now
Message 10 of 10
Getting the hang of it now:
https://imgur.com/TVEgTCE
Kudos to you
Kudos to you
