Needhelp to make this oval hole in a box
The box is 14x10x2 cm
the oval hole is:
1 cm deep
8 cm wide
12 cm long
Se image
the oval hole is:
1 cm deep
8 cm wide
12 cm long
Se image
What version of Inventor are you using?
Can you Attach your attempt here?
I'm using version 2019
Please find the attached part.
If it solves your issue then accept it as a solution.
Cheers,
Bhavik Suthar
https://www.linkedin.com/in/bhavikpsuthar/
Yes that's what I'm looking for.
I would like to learn something new, is it possible that you are making a small video showing your workflow.
Have looked in the attachment *.ipt file, but can't figure out how you make it
Thanks in advance
I have uploaded a screencast for your need.
https://knowledge.autodesk.com/community/screencast/11107d7a-3653-497d-91ee-cbe3339fe15b
Please accept as a solution if it solves your issue.
Cheers,
Bhavik Suthar
