Box with oval hole - need help
steenH797P
steenH797P
Needhelp to make this oval hole in a box
The box is 14x10x2 cm
the oval hole is:
1 cm deep
8 cm wide
12 cm long
Se image
Cris-Ideas
Loft will produce this kind of shape.
Cris.
Cris,
https://simply.engineering
JDMather
What version of Inventor are you using?
Can you Attach your attempt here?
steenH797P
I'm using version 2019
bhavik4244
@steenH797P ,
Please find the attached part.
If it solves your issue then accept it as a solution.
Cheers,
Bhavik Suthar
https://www.linkedin.com/in/bhavikpsuthar/
Bhavik Suthar
steenH797P
Yes that's what I'm looking for.
I would like to learn something new, is it possible that you are making a small video showing your workflow.
Have looked in the attachment *.ipt file, but can't figure out how you make it
Thanks in advance
bhavik4244
@steenH797P
I have uploaded a screencast for your need.
https://knowledge.autodesk.com/community/screencast/11107d7a-3653-497d-91ee-cbe3339fe15b
Please accept as a solution if it solves your issue.
Cheers,
Bhavik Suthar
Bhavik Suthar
