BOM Export Missing Parts
gyurcsangyorgy99
gyurcsangyorgy99
Hello Community!
I experienced a very frustating problem when i exported BOM from Inventor Pro 2025.
I exported an Structured - All levels BOM to Excel, and after a while i saw that list does not contain all of the items from the Modell.
I checked every BOM structure, every component, subassembly, and i could not find any problem with them. I tried to export again, and then the missing components were there, but others missing.
I used an excel template, but get the same result if i export without it.
If i export an Part Only, it shows all of the components (As i saw, but now i am not sure about that), just the all levels structured seems to be faulty.
I tried to export from an subassembly (the missing components are in an deep level), and this time the missing components were there.
As i saw, only that parts/assemblies were missing, which contains model states, or the parent assembly contains model states.
Anyone faced with that problem before? What can i do to be sure all of my components are exported?
(I cannot upload or send files, unfortunately)
Thanks for help!
  • BOM
johnsonshiue
Hi! The behavior does not sound right to me. It could be a BOM corruption or component instance corruption. Please share the files in zip with me directly at [email protected].
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
SharkDesign
I would also check the BOM structure for the missing parts as things like Phantom/Reference have an affect on whether they are shown or not (and their children.)
  Inventor Certified Professional
gyurcsangyorgy99
Unfortunately, i cannot share files, because of company policy.
What do you mean in instance corruption?
gyurcsangyorgy99
I checked the bom structure, and it is good.
The missing components appeared when i export the bom 1 level below ( from subassembly), without any modification.
So the problem has to be somewhere else.
johnsonshiue
Hi! Open the top-level assembly and go to Manage -> Rebuild All. After that, does it work better then?
Many thanks!
