Boltholes Flanges
Boltholes Flanges
Wouldn't it be great to have a command to draw these holes at once, instead of modeling 1 hole, model another hole and do the circular array...
Just sketch a point as if you would model a normal hole, but than have the option to have a bolt circle around..
gcoombridge
It's called iFeatures! They are a bit awkward to make at times - especially if you want to revolve features but this is a perfect application. You can include tables like an ipart to have multiple sizes/configurations, I have made them for a number of ANSI flanges (adding geometry rather than removing it but the process is the same)
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
