Bolted connection to slots
IB55
IB55
It is very common to have slots instead of holes for expansion or adjustability of the connection. Can inventor design bolted connection through slots?
blair
I guess you could use the Linear option
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
blandb
This is kind of a cheating way of doing it, but you could make a circular cut at the center of your slot that is just say a .001 larger than the slot. Then you could use the "Concentric" method using the circular cut-out as the reference.  Just a thought.
Autodesk Certified Professional
blair
Or use at a Point but as with the sketch, they both add geometry to the model. Most likely, you will have a hole on the other side of your model so I would use it to "anchor" the hole.
The Bolted connection does require starting and ending planes and then a location point, I've never seen very many slot/slot connections.
Delta Tau Chi ΔΤΧ
IB55
Blandb that is a very good trick, not exactly what I was looking for but your idea can be very useful. I was more hoping to get some ideas how to customise bolted connection tool so it will create slot (or slots) in bolted parts. If I have to create slots in addition to the bolted connection then all the productivity associated with the bolted connection is lost.
Thank you all for your ideas and suggestions.
LukeEngineering
For anyone comming here through g00gle.
Use the Joint feature, or if you don't want any joints in you assembly:
In the part with the slot: Make a Work Feature point with the "Center Point of Loop of Edges".
In the assembly: Put your bolt/washer at the plane with a constrain and then add a constraint to the centerline of the bolt and the specified point.
It still is some work to add all the points.
