Bolted Connection Thread units
Cosmin_V
Message 1 of 25
Cosmin_V
Hi
I'm trying to use "Bolted Connection Component Generator", but for some reason if I change the thread from
"ISO Metric profile" to one of our standard the units it change from "mm" to "in".
How this can be fixt?
Replies (24)
Message 2 of 25
andrewdroth
Are you changing the thread to a custom diameter, or a custom thread profile?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Message 3 of 25
Cosmin_V
Thanx @andrewdroth
A custom thread profile.
Message 4 of 25
CGBenner
@Cosmin_V
Can you attach one of your parts here with the custom profile?
Chris Benner
Message 5 of 25
Cosmin_V
No, unfortunately I'm not allowed to. 😞
Message 6 of 25
CGBenner
@Cosmin_V
I recently saw something similar, with a pipe fitting.  The part model was created using Imperial units, but the size parameter was manually set to Metric (mm).  Inventor ignored the parameter setting when the part was authored and published, and used inches instead of mm.  Check your original part model units, to see if it was modelled in inches or millimeters.
Chris Benner
Message 7 of 25
Cosmin_V
It was in mm, everything is in "mm", we don't use and we never used "in".
Message 8 of 25
CGBenner
@Cosmin_V
Sorry,... had to ask.  I assumed that it was in mm, but I thought it was worth checking.
Chris Benner
Message 9 of 25
johnsonshiue
Hi! The behavior does not sound right to me. But, I need a way to reproduce it. Please try publishing a non-proprietary part and see if it behaves the same. I would like to see an example. What release of Inventor are you on? Please make sure all applicable Inventor updates are installed.
Many thanks!
Software Test Engineer
Message 10 of 25
Cosmin_V
HI
In fact I don't even have an example to show because I didn't make one, if it's wrong ...
This is what it is happen
If I change the thread from ISO "Metric profile" to one of our "Standard"
The Diameter it is change from "mm" to "in"
Message 11 of 25
CGBenner
@Cosmin_V
How did you define the thread designation?  The method you used there might hold a clue to what is going wrong.
Chris Benner
Message 12 of 25
johnsonshiue
Hi! I suspect the family template associated with the CC family might be wrong (inch based). Try this. Open a CC part from the family and go to Tools -> Doc Settings -> Unit. Is it set to "inch" or "mm"? If it is inch, change it to mm. Make sure all other settings are correct. Then go to CC Editor -> find the family -> replace family template -> pick the part you just save. Does it work better now?
Many thanks!
Message 13 of 25
Cosmin_V
It is in "mm"
Message 14 of 25
CGBenner
@Cosmin_V
Did you see my post above?  How was your custom thread designation created?
Chris Benner
Message 15 of 25
Cosmin_V
I'm sorry, I didn't see your post.
I don't know exactly how, I was there ...
Message 16 of 25
CGBenner
@Cosmin_V
Can you share the Thread.xls data file from your system?  It is normally found at: C:\Users\Public\Documents\Autodesk\Inventor 201x\Design Data\XLS\<language folder>\.   You couls also find it through a search in Windows Explorer if that does not work.
Chris Benner
Message 17 of 25
Cosmin_V
I hoppe it is ok
Message 18 of 25
CGBenner
@Cosmin_V
Thank you!  Which family is the one that is giving you the size error?  Is it the Kleecoil?
Chris Benner
Message 19 of 25
Cosmin_V
Thank you @CGBenner
Yes, it is the Kleecoil!
Message 20 of 25
CGBenner
@Cosmin_V
In the Thread.xls file that you sent, I noticed that the "Size" column is populated with the value from "Thread Designation".  In all of the other tables, Size is an Integer, Thread Designation is a String.  I suspect that putting the correct Integer value in this column may fix the problem.
This is the Kleecoil table:
By comparison, this is the ISO Metric table:
Chris Benner
