Bolted connection Problem
Message 1 of 10
How to select multiple circular references for bolted connection or clevis pin ?
Replies (9)
Message 2 of 10
HermJan.Otterman
If you have the holes allready created, then select placement by hole, and not concentric.
after selecting the first hole you get an option te select a pattern checkbox, check that
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 3 of 10
Thanks for helping me.
If I select placement by hole than it's not possibal selecting a hole.
The holes are allready created, so I still have a problem.
Met vriendelijke groeten | Meilleures salutations | Mit freundlichen Grüßen | Best regards
Hans Balcaen
[cid:147B61BC-FAB0-4882-9CB6-3FF1BE5F0E78@home]
Evolis 100 | 8500 Kortrijk | Belgium
T +32 56 210 210 / +32 477 66 47 70
hba@avc.eu | www.avc.eu
[Beschrijving: Beschrijving: Beschrijving: Beschrijving: http://screenshots.nl.sftcdn.net/blog/nl/2012/02/facebook-logo.png][Beschrijving: Beschrijving: Beschrijving: Beschrijving: http://axelweydts.files.wordpress.com/2011/06/twitter_logo.jpg] [Beschrijving: Beschrijving: Beschrijving: Beschrijving: Beschrijving: Beschrijving: Beschrijving: Description: Think Green]
Message 4 of 10
HermJan.Otterman
I made a screencast.
the problem is that the holes are not created with the hole feature, but with an extrusion of a circle.
make the holes with the hole feature and it will work
http://autode.sk/2lKGxHq
Herm Jan
Message 5 of 10
The same problem occured when I want to do this with Clevis Pin even when I make the the holes with the hole feature.
Is there a solution for this problem.
Hans Balcaen
Message 6 of 10
johnsonshiue
Hi Hans,
I think I know what you want. I believe you have a hole feature and a pattern of the hole, right. The workflow is not intuitive. Here is what you need to do. 1) BoltConn -> By Hole -> pick the main hole.
2) Check "Follow Pattern" -> Ok.
The BoltConns will be created.
Could you take a look and see if it works for you?
Many thanks!
Software Test Engineer
Message 7 of 10
I have the same probem when i want to do that with Clevis pin even when i make the holes with the hole feature???
Message 8 of 10
HermJan.Otterman
Hello John,
this is exactly what my screencast is showing!
Herm Jan
Message 9 of 10
HermJan.Otterman
why this is not working for the clevis pin I don't know, Autodesk has to do something there, maybe because most of the time you will be placing only one? at a time??
but oke, if you want to place multiple, place them directly from the content center
- assemble, place from content center
- turn on Auto drop
- select your pin
- select the hole, (because of the autodrop, the size is adapted)
- now you get the option to do this for the other holes as well, so place multiple
Herm Jan
Message 10 of 10
johnsonshiue
Hi Hans and Herm,
Indeed, the workflow following the hole pattern is only available in Bolt Conn, not in Pins. It looks like incomplete implementation. I guess it was assumed that following hole pattern on placing a pin is not frequently used. Could you go to Inventor Ideas and post an idea?
Many thanks!
