I have a CMD filter name created.
What needs to be done to display it to me when creating a screw joint?
Solved by CGBenner. Go to Solution.
@krupickaRZCS6
Hello! In your Content Center Editor, check the fasteners that belong to the CMD filter and make sure that CMD is in the Standard Organization field as shown here:
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Is this Library active for current project?
May be You need not select for CMD all other standard and unselect Manufacturers
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
