Bolted Connection Component Generator didnt work
Message 1 of 11
Hello guys,
While i am working i need use the BCC Generator but my bolt box is empty. Than i looked forums and did something but not succeeded. I think program cant see this folder what can i do ? ( Autodesk Inventor Professional 2017 ) btw sorry about my English 🙂 not perfect like you guys 🙂
Replies (10)
Message 2 of 11
johnsonshiue
Hi! Please go to Tools -> Application Options -> Content Center. What is the location for CC Libraries?
Many thanks!
Software Test Engineer
Message 3 of 11
This is my content center location file
Message 4 of 11
johnsonshiue
Hi! If you go to File Explorer and go to the CC Library folder. Do you see idcl files? Could you place a CC component (Place -> Place CC Component -> pick a component in CC library)? If not, the CC may not be installed properly. You may need to do repair install.
Many thanks!
Message 5 of 11
Thanks for your interest.Firstly i see all of idcl files. I can pick up component from cc directly but if i want use bcc generator i still cant see any materials.
Message 6 of 11
Xun.Zhang
Hi!
Have you upgrade to the latest update such as 2018.2?
Xun
Message 7 of 11
My program is up to date says autodesk site.
Message 8 of 11
guosu
Hi! It seems diameter you specified in Bolted Connection Component Generator dialog is not suitable, so no family in CC library are matched. Please try to specify a suitable diameter.
Sucy
Message 9 of 11
I tried that but result is same again. Formatted my pc installed again same result.Maybe program which i downloaded is damaged ?
Message 10 of 11
johnsonshiue
Hi! Did you change the diameter of the bolt in the Bolted Connection Dialog? If the chosen diameter is too small or incompatible with the selected hole, there will not be any bolts to choose from. If you still cannot figure out, please feel free to share the files here and forum experts can comment further.
Many thanks!
Message 11 of 11
Ooh thank you Mr Johnson  Shiue and guosu for your helps i did it finally. I chosed wrong diameter. You guys perfect helper than google 😄 thanks a lot..
