Bolted connection: Cannot initialize part data table
gcarvac
Message 1 of 8
gcarvac
Hi.
I've authored and published a custom nut to content center, and am trying to use it in a bolted connection. However, when trying to place an M14 nut, I get an error saying Cannot initialize part data table. However, I can place the nut from content center when not using the bolted connection tool.
Replies (7)
Message 2 of 8
johnsonshiue
Hi! I suspect there is some sort of mismatch between the family table of this newly published nut and the thread table. Does this custom nut use a custom thread table (not the one shipped with Inventor)?
Please share the publish ipt here. I would like to work with the project team to understand it better.
Many thanks!
Software Test Engineer
Message 3 of 8
gcarvac
I don't believe its using a custom thread. Pretty sure I just used the hole tool for M14. I've attached the part.
Message 4 of 8
jan_priban
better is to publish iPart. Content Center is designed to "consume" iPart. Basically conversion iPart -> CC part goes smoothly than regular part -> CC part. My suggestion:
- convert your silicone nut to iPart
- add into iPart table also thread properties (image Make_iPart)
- re-authrorize
- publish
- Bolted Connection (Place from CC) works smoothly
Regards
Jan Priban
Message 5 of 8
gcarvac
Ah sorry, got confused. I did create an ipart. Here it is. Sorry for the confusion!
Message 6 of 8
gcarvac
@johnsonshiueor @jan_priban Was there any more advice you can give?
Message 7 of 8
santony_ary
Observer
Observer
Hi @gcarvac,
Have you found a solution for this?
I've just successfully created Metric-Nylock Nut on Autodesk inventor which can be utilized on Bolted Connection in Assembly features
Just additional step from @jan_priban post above.
-setup a user parameter NMD (for example) and insert the number 4 (for M4).
-then ipart, ensure you have those items, I found NMD and Nom_Dia_Designation are required, number need to be adjusted to Nut Size anyway. I found it with "M" and without "M" will affect the process
-next, follow Component Authoring as per pictures and make sure those parameter from ipart are mapped.
 1 Parameter1 Parameter2 ipart author2 ipart author3 Component Authoring (a)3 Component Authoring (a)3 Component Authoring (b)3 Component Authoring (b)3 Componenr Authoring (c).jpg3 Componenr Authoring (d).jpg3 Componenr Authoring (e).jpg
Cheers,
Ary Santony
Message 8 of 8
gcarvac
No, and Autodesk never got back to me.
