Inventor Forum
Boat Propeller
9 REPLIES 9
Message 1 of 10
1877 Views, 9 Replies
Boat Propeller
Does anyone have any idea on how to draw boat propeller wings?
9 REPLIES 9
Message 2 of 10
Rob67ert
Hi there and welcome to this forum.
Do you have a picture os what it should look like?
Most propeller wings are calculated and that data is used to make the drawing.
You will get cross sections in data sheet like excel.
That data you can then use to make a model of is.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 10
Lewis.Young
Hi there,
Attached is an idea of how you could model the propeller.
Obviously I've just made up these values, but as Robert said, they'd realistically be modeled straight from calculations.
Anyway, hope this has helped!
Lewis
Message 4 of 10
JDMather
What version of Inventor?
Can you attach your initial attempt here?
Message 5 of 10
jhackney1972
Lewis Young had the basic same approach using surfaces but you can cut out a lot of work by just sketching a rectangle and use the coil command to make one blade.  After that, add your fillets to the edges and then pattern.  See the attached pictures.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 6 of 10
in reply to: JDMather
Hey thanks for the help,
My version is 2018 and the problem I'm facing is that the coil tool is not working because the two ends of the wings are not the same size or shape. In addition, the main section of the Propeller is shaped like a cone and I am having trouble lofting to the surface properly.
Thanks Again,
Trevor Belson
Mechanical Engineering Major
SUNY Maritime College
Message 7 of 10
in reply to: jhackney1972
Thanks for the help!
Message 8 of 10
in reply to: Rob67ert
I'm having trouble because the coil tool wont work properly for this propeller design because the ends of the wings are different widths and thicknesses. Also, the main section of the propeller is a truncated cone and it is difficult use loft for the wings. Attached is my file and a couple pictures of the propeller.
Thanks Again,
Trevor Belson
Message 9 of 10
JDMather
Has your instructor covered the importance of fully defining your sketches?
What is the logical purpose of Workplane1 (how is it different than the XZ Plane)?
What is the logical purpose of Workplane2 (how is it different than the XY Plane)?
Can you show pictures of the actual part without shadows?
Can you show picture of the bottom of the part?
Sketch11 should have been one single circle - it is preferable to pattern features rather than sketch elements.
Sketch10 should have been one single circle - it is preferable to pattern features rather than sketch elements.
 The holes on your model are not equally spaced while they appear to be equally spaced on the original model?
If I do a section view - I see a very thin section that I would not expect to mold properly.
Message 10 of 10
Vadim-the-Engineer
There are dozens of types of boat propellers with different loads, purposes, and design specifications... might be very useful to going theory and finding the one you want and while this you'll find the data you are looking for: dimensions, proportions, angles etc....
If lazy: GrabCAD 😄
Technology Administrators
