Have you tried just adding chamfers or fillets to the text edges?
How much text are we talking?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Can you use "extrude with taper" instead of emboss?
Or maybe "decal"
I don't understand why the German version would be different, but I will take your word for it.
While I am not much of an iLogic guru, when it comes to odd things like this with no visible solution, makes me wonder if iLogic would work to give you the desired results.
