I want to create a solid blade @3mm thick (approx - .ipt attached for blade profile) I tried the following steps, but it can't work,
1. Create sketch profile
2. Create lofted surface
3. Thicken the lofted surface
Solved by blandb. Go to Solution.
Did you import these points with points only then add the lines? When you import points via a sketch, choose the options button just next to open and choose create spline, do you get a better result?
Def. check sketch 2 as it is causing some twisting.
I removed the lines from the sketches and added a spline instead. Please see attached 2024 part.
Notice the difference.
Before:
After:
