I can only sort by the last column of custom Iproperties and not by multiple. This worked on previous versions of Inventor.
Solved by johnsonshiue. Go to Solution.
Hi!
I don't understand how you can select twice "productieType1"!!
Have you installed all inventor updates?
Hi Carlos and Geert,
This is indeed a bug, starting from 2023. Geert's image shows the bug. Somehow the selected custom iProperties on the Sort dialog become the same. It has been reported as INVGEN-62446. Hopefully, it will be addressed soon.
Many thanks!
