I can make a spring but the ends are tricky what is the easiest way to do that?
Solved by JDMather. Go to Solution.
I want you to read your post and ask yourself, did you include enough information to recieve a useful response?
YEA SORRY ABOUT THAT I AM SUPER BUSY AND I AM ABOUT TO GO CRAZY MY GRAPHICS CARD IS GOING OUT ON ME AND IS CAUSING ALOT OF STRESS.( I KNOW THIS IS OFF THE SUBJECT BUT CAN ANY OF YOU TELL ME A GOOD GRAPHICS CARD THAT I CAN GET THAT WILL HOLD UP TO THIS SOFTWARE) I NEED TO KNOW THE BEST WAY TO DRAW THE HOOKS ON THE ENDS OF A SPRING I HAVE ATTACHED A PICTURE OF THE SPRING THANKS
This is a little more than you need, but if you can tie a knot in Inventor
http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
3d sketch intersection and sweep.
