best way to add threads for printing purposes?
DavidTunnard
Message 1 of 32
DavidTunnard
I need to add actual threads to some parts for 3d printing. Currently, I am using the cool orange thread modeler which works great when you only have a couple of threads to do. However, the current part I am working on has a load of holes with threads. Usually, if I didn't need to model the threads, I would just pattern a threaded hole. Unfortunately, I don't think that the CoolOrange thread modeler works for threaded holes which means that adding modeled threads for all of these features is a right pain.
Anybody got any answers for how to make this process easier?
At the minute my only idea is to import the part into Fusion360 and add the threads there as that has an option to add modeled threads when placing the hole. Would be great if Inventor could have this feature.
Replies (31)
Message 21 of 32
terpdeich
I have made a punch tool for external thread based on your video. In my testing so far it works.
I have attached the part file and the iFeature file in a zip-folder
The punch tool is to be used on the center of the end face of a cylindrical body with the diameter of the desired thread size without accounting for tolerance - that will be done by Clearance in the the punch tool settings.
Message 22 of 32
Frederick_Law
You need to zip the files to attach here.
Message 23 of 32
terpdeich
Thanks! I have attached that now in my edited post.
Message 24 of 32
Hi All,
I haven't tried the punch tool from terpdeich yet, sorry about that! Well, I have stopped using the orange thread modeler as it proved to be too much work to constrain it to the actual part, plus it couldn't do enough, such as chamfers and runout. For that purpose, I've made a template with Sketch Blocks. Yep, I can explain the process if people are interested. The Sketch Blocks look like this:
Real screw threads 60 degrees metricReal screw threads 60 degrees metric
The template's parameters pane looks like this:
Template real screw threadsTemplate real screw threads
And placed in a part: a throttle shaft:
Throttle shaft w/screw threadsThrottle shaft w/screw threads
I have attached a PDF document containing a link to a 7-minute or so screen recording of me using these Sketch Blocks. Of course, if you have any questions or would like to have the template (IPT), let me know. Cheers, Marco
Message 25 of 32
terpdeich
It definitely looks good and realistic.  The punch tool I made would need tweaking to have a proper round out (for now is just has a shoulder option) and round outer edge of the thread (the latter would be a quick fix in the sketch).
The purpose of the punch tool is for 3D-printing where it's necessary to be able to change tolerance/clearance.
I didn't pick up if your method had that feature?
Also once the punch tool iFeatere is added - it takes literally 30secs to make the thread on a rod.
Message 26 of 32
Right, I'll have a go with the punch tool. Thank you for providing it! My method has no tolerance or clearance setting.
Message 27 of 32
terpdeich
I hope it can work for you. If the right tweaks can be made - it could potentially save you a lot of time 🤞
Message 28 of 32
karthur1
For anyone interested, here are the models and .ide for Imperial, Metric and NPT internal threads.
The attached .zip has the models and the .ide files that can be placed into printed parts. The clearance for the NPT threads is set to .005in, but you can change it depending on your printer.  The inch and metric threads has a field where you can adjust the clearance when you place the feature.
Hope this helps.
Kirk
Message 29 of 32
ofonime.william
I was wondering how to effectively the "Modeled V......" @karthur1 , I'm using Inventor 2024, online version of coolorange is not an ideal for me either.
Message 30 of 32
karthur1
I have used this for several different projects and it works well.  You should know what tolerance your printer is capable of and do a few test prints to see how it works.
Message 31 of 32
andyasskwoo
Community Visitor
Community Visitor
You can include them by selecting "Modelled" in the threads tool.
Message 32 of 32
JDMather
@andyasskwoo
You are in the wrong forum.  That is Autodesk Fusion.
