Best practice to model round and square overlapping rebar?
jeffrey.s.barrero
Message 1 of 10
jeffrey.s.barrero
Good day ladies and gentlemen
Does anyone have any suggestions to model an overlapping circular shape or geometrical shape? Where complete length, radius, and overlapping distance can be measures or adjusted independently.
If anyone have any suggestions or advise as to where I may look to find this information, I will greatly appreciate it.
Thank you all and wish you a great day
Replies (9)
Message 2 of 10
Cadmanto
I would use the coil command.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
JDMather
Is that planar (hard to tell from the image)?
Can you Attach your ipt file here?
Arc_Length parameter(s) are my first thought.
Message 4 of 10
blandb
Your image appears to be an overlapping coil.  If you use a 3D sketch, you can create a helix and control diameters, pitches, revolutions, etc. Unfortunately there isn't a parameter for length. You could rename the parameters entered so you know what they are in the parameters dialog box for easy manipulation of coil sizes, but as for getting the length other than measuring the helix (if that is your profile centerline) and placing that value into a custom parameter. But, that is not ideal. Other than that, I'm not certain. Programming might be able to pull the helix length into a parameter for use, but I imagine that others will have a good solution for you.
As @JDMather  mentioned, if it is just planar, using formulas utilizing parameters will get you there.
Autodesk Certified Professional
Message 5 of 10
JDMather
@blandb wrote:
.... Unfortunately there isn't a parameter for length. ...
@blandb
I thought this was added in 2019, but now I can't find it?
Message 6 of 10
jeffrey.s.barrero
I've used the Helical tool, but I do not see where or how can measure of rate specifics in material length, distance of overlapping, etc. Perhaps I am not thinking it as I should, or I may not be thinking enough LOL.
I wanted to see if there were any suggestions or advise in accomplishing what I am looking for.
Thank you all
Message 7 of 10
blandb
I stumbled across this, it may help you:
https://forums.autodesk.com/t5/inventor-forum/inventor-distance-of-coil-spiral-and-pitch-instead-of-...
Message 8 of 10
mpatchus
See if you can make use of this....
https://forums.autodesk.com/t5/inventor-forum/coil-tool-misuse/m-p/3610626
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 9 of 10
blandb
Are you thinking of the dimension on a spline maybe?
Message 10 of 10
johnsonshiue
Hi Guys,
Here is a solution using a straight line and 3D wrap-around curve (see attached part). It should work with various dimensions.
Many thanks!
Software Test Engineer
