- Mute
- Permalink
- Report
When using Model States and Positions I often find myself annoyed that I cannot give the [Primary] Representation a name that communicates its intended purpose. This has led me to use a couple of different work arounds, neither of which I am particularly happy with:
- Make the [Primary] Representation a dummy state that is not intended to be used.
- Leave it to the user to deduce what the [Primary] Representation is relative to the others in the list.
I have also found an instance that I would like to Exclude some Positions from an iAssembly that I have been upgrading, but I cannot Exclude the [Primary] Position. I have considered a few work arounds similar to the above to this as well:
- Make the [Primary] Position a dummy, I can make the other Positions override a constraint value to make this obvious.
- Just leave it to the user to understand that they should not use that the [Primary] Position in those particular iAssembly Members that I would Exclude if I were able to.
- Abandon the use of Position Representations and build them into the iAssembly Factory, adding many, many, many rows to the Table.
What methods do you guys find the most success with? Am I missing one?
