Hello
What is the best method for backing up inventor? Do the seagate type drives work? maintain the structure if a computer had a major crash? what about Sticks?
Also is there a cloud solution? what about plkatforms like carbonite. Our company is small so big $ is not an option.
thanks
Craig Williams
Mesocore.com
If you are using Inventor you can use Vault and that has automatic backup options. The bigger question is...why are you not using Vault now for archiving projects or performing copy designs?
Even if you only have 1 or 2 users, there are still reasons to use Vault.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
If you are using Inventor 2015 or 2016 and you have Subscription you can put everything in the A360 Cloud (25GB storage) and access it right through Inventor.
Other storage options that are low cost are Dropbox for Buisness or Box.net (these two just don't have integrations like A360.
I am not sure I was given good information but I was told to use vault would be as much as 30k to get setup. Like I said we are primarily just using one seat of our two. Our version is the building design suite 2013. right now we use mostly inventor some Autocad. Its on our list to expand to some other applications but just too busy in development so far.
Craig
Mesocore.com
Contact your reseller ....
See why they say it's 30k. A basic vault shouldn't be much at all for your IT dept/person to implement.
If it seems wrong still ..then contact a different reseller.
However you should be using vault or A360..
if it's not possible, then do it with your network backups
BY "BEST BACKUP" do you mean
backing up :-
a) all installed programs, the entire HD?
b) Just your "My documents"?
c) Just the Inventor folder & files?
Then for:-
a) Use a mirror copy program, I use Casper, you'll need a second HD the same capacity as your master for a perfect mirror image. advantage here is if C goes down just change the data cables, if you need to replace the dodgy HD, and run the mirror program to mirror to the new/reformatted HD,
b) Use the Windows file backup, backing up to anywhere you like, I use a third HD for this with a 2TB capacity deleting backups more than 6 month old, saves space and search time when having to, very really, restore data.
For c) Again use the widows file backup BUT specify which files you want to backup
ALWAYS make sure that you have the LATEST/MOST RECENT systems restore that you backup/mirror at least once a day or more depending on your workload with either method your data can be saved to a separate HD or external device, all 3 options can be used to backup/mirror to an external device/s you just need to let the program doing that backup/mirror know the source and destination.
YOU MAY, or should I say, WILL loose some of your most recent data depending on the settings that you use in any of these options but loosing some is better than loosing everything.
Personally I used BELT, BRACES and a PEACE OF STING backup methods in that I mirror daily to internal HD, Windows Folder & File backup weekly to internal HD and usually the Windows Folder & File backup "My Documents" folders to DVD once a month. Yes I'm old school, about 30 years as a computer user has taught me the hard way that as far as backing up is concerned "you can never backup enough often enough and to too many locations - that way its always available if the worst happens"
