- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am using Inventor and me and my company never used it before. since it is one of my first sheet metal component I am creating , I am facing few issues. The models I created have several bends. These components are laser cutted and therefore manufactured on a press brake. I need to know the dimension to input on the press brake so the back gauge stops on the right place. The first bend is not difficult, because I can see the dimension from edge to the bend center on the flatt pattern. the second bend needs a dimension from the flange of the first bend to the bend line of the second bend for a back guage setting. However, I cant see this dimension. I have searched other similar posts but I couldn´t understand it very well:http://forums.autodesk.com/t5/inventor-general-discussion/dimensions-for-press-brake/td-p/4383084
I am able to see the the press brake back gauge distance for 1, but not for 2
Any help is welcome, Thanks
