Inventor Forum
Bending a Pipe
4 REPLIES 4
7713 Views, 4 Replies
Bending a Pipe
I'm tryign to draw a grab bar using aluminum tubing. In the end, the grab bar will have 4 bends but I am having trouble creating even the first one. I started with a solid extrusion of OD: 1.25in and ID: 1in extruded for 12ft. I then make a sketch plane through the solid extrusion, and sketch a line on the plane tangent to the edge of the pipe. When i use the bend command and select the sketched line (to make it a bend line), no matter what radius or angle i enter, the pipe will not bend and I get an error saying:
"The attempted operation did not produce a meaningful result. Try with different inputs"
I've tried placing the line at different positions throughout the cross section of the pipe, chaning the angle and radius over a wide range of values, and tried with extruded solid vs swept solid. Nothing has worked.
Any ideas?
It's a simple part but I'll attach the file for convenience.
Bending a Pipe
Any ideas?
4 REPLIES 4
Make a new plane that is parallel to your XY plane and tangent to the outside surface of the pipe.
Create a sketch on that new plane and draw a line where you want your bend to start.
Now try the bend tools again I think you will be more successful.
It look slike you almost had it right. You are just drawing your bend line on the wrong plane.
mcgyvr
mcgyvr
Any ideas?
Don't use bend part...
Simply do a sweep.. This would be done with 2 sketches.. 1 the profile of the bar (probably just a circle) and then the second sketch is the path the whole bar follows or the shape of the whole grab bar.. Then simply sweep to create it.
http://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Inventor-Help/files/GUID-CECD103F-A572-423D-BC9E-2DDFD0FB239A-htm.html
Any ideas?
in reply to: mcgyvr
Thanks for the suggestion!
I guess I should explain, I had actually already created this part using a sweep. This bend porblem I was trying to solve was actually just for a test to see if inventor would deform the solid during a bend as would happen in real life. Using the sweep function the cross-section of the tube remains constant around a bend.
mcgyvr
mcgyvr
Yeah.. Inventor won't deform as in real life.
