bend table question
Ive been using a static k factor and its been working for me fine until we got a new die and it doesn't work with our k factor i have set up.
So now im trying to set up a bend table for different radii and everything so i dont need so many templates for different dies and such.
Only problem i have is, i don't know how many pieces i need bent/how many angles i need to record.
Our shop primarily uses 4 different gauges of Stainless Steel.
If i have them bend me a piece 4" x 4" at 45, 90, 135 degrees; could i make my bend table off of those numbers?
Or do i need them to bend me pieces all 5 degrees off of each other like all the other tables Ive seen?
Also when it comes to bend tables, the columns on the left are the angle and the top is the radius, but how do i get the numbers to fill in these spaces? i saw a formula of L=A+B-x from
but Im still in the dark about using that since i dont completely understand it at the moment.
Any help is greatly appreciated
