Inventor Forum
Bend notes on drawing
3 REPLIES 3
3126 Views, 3 Replies
Is there a way to make Inventor automatically add a note, along the bend line, indicating bend direction, number of degrees and bend radius?
Also, in 2013, where are the bend tables located?
I've checked the help file, and it's telling me c\program files\autodesk\inventor 2013\design data
I followed that path, but I do not have the "design data" folder it's calling for.
Thank you very much for your help.
3 REPLIES 3
bobvdd
To add bend notes:
Annotate > Feature Notes > Bend
Edit the bend note or Edit the dimension style used for the bend note to add more options
The bend tables are in:
C:\Users\Public\Documents\Autodesk\Inventor 2013\Design Data\Bend Tables
Bob
Bob Van der Donck
Principal UX designer DMG group
in reply to: bobvdd
Thanks so much for the reply.
I've attached a screen shot showing the path you have listed,
but nothing called bend table.
Is there somewhere else it could be hidden?
Thanks again for the help.
bobvdd
Yup, the bend tables are clearly missing from your installation.
I have attached a copy of those files to this post. Try unzipping them to the folder I mentioned earlier.
If that still does not give you bend tables in a drawing, try a repair of Inventor.
Bob
Bob Van der Donck
Technology Administrators
