Bend drawing
Bend drawing
samsTJN3U
Bend drawing
samsTJN3U
Hello everyone, I hope you guys are safe in isolation bubble. My prayers for everyone.
I am trying to complete the bend. Please see attached drawing and photos. The 710mm dia plastic pipe is firstly bending at 25 deg then second bend of 65 deg taking the pipe away from us then again some sharp angle say 25 deg directing the pipe towards us. Each bend has small segments. I could do only first angle in one plane but got stuck in complete other two angles. If anyone could help will be great.
Thanks experts.
JDMather
Attach the *.ipt file of your attempt here.
samsTJN3U
Please receive attached ipt file. Thanks
johnsonshiue
Hi! This can be done easily by using Sweep or Bend Part command.
Many thanks!
Software Test Engineer
samsTJN3U
Hi Johnson, I am trying to draw as per picture attached. Looks like multi plan drawing to me.
johnsonshiue
Hi Sam,
I will say this should be done via Sweep. It would be more straight forward. Regarding the Sweep path, you will need to decide if it is a 3D Spline or 3D Line/Arc or combination of the two.
Many thanks!
samsTJN3U
Thanks, I will try.
